v0.76: "Multiple view for same file" opens tabs twice
sucrilhus
Post by sucrilhus »
If I activate "Multiple view for same file" option under Settings > Interface > Interface, upon opening an image once it will automatically open 2 tabs with the same image.
On the previous versions, the "Multiple view for same file" opened only one tab... which made more sense, since the idea is just allow the user to re-open the same image in different tabs if they want to... but not necessarily always open 2 tabs each time.
Was this change intentional? Or am I facing a bug?
Thanks in advance
My System:
Windows 10
XnViewMP v0.76 x64 (Oct 23 2015)
Bartfratze
Re: v0.76: "Multiple view for same file" opens tabs twice
Post by Bartfratze »
Can confirm this with Linux + XnViewMP 0.76.
Guess it's a bug, 'cause reopening doesn't happen on every doubleclick.
See Issue 735 for current status and details.
This problem is supposed to be fixed in XnView MP 0.78 or later. Could you please try and confirm the bug fix, sucrilhus or Bartfratze?
