Segmentation fault
EVApanda
Segmentation fault
Post by EVApanda »
I just upgraded to latest. Downloaded 64bit tarball for linux.
Getting this error when I launch:
./xnview.sh: line 5: 10455 Segmentation fault (core dumped) "$dirname"/XnView "$@"
Re: Segmentation fault
do you have tried to replace executable with one of these:
Linux 32bits Linux 64bits
texstar
Post by texstar »
The Arch version works for us as well.
PCLinuxOS
kernel 4.1.12
xorg 1.17.4
mesa 11.0.4
EVApanda
Post by EVApanda »
Thanks, that executable works, but it's 0.75?
Is there one for 0.76.1?
EVApanda wrote:Thanks, that executable works, but it's 0.75?
The 2 links are 0.76.1
EVApanda
Post by EVApanda »
xnview wrote:The 2 links are 0.76.1
If I use that executable from the link it says 0.75.
x32 or x64?
EVApanda
Post by EVApanda »
xnview wrote:x32 or x64?
x64
x64
it's fixed
EVApanda
Post by EVApanda »
Thank you. Much appreciated.
EVApanda
Post by EVApanda »
Hi, same problem as before.
Link in Downloads section for Linux 64bit is old version 0.76.1, not 0.78.
Thanks
Edit: Maybe I'll start a new thread. (No segfaults here, sorry)
EVApanda wrote:Hi, same problem as before.
Thanks
this link? http://download.xnview.com/XnViewMP-linux-x64.tgz
