Can't open files/folders containing letters č, ć, đ
suppertime
Post by suppertime »
Any way to fix this? There aren't any issues with letters ž and š. If you need to test this, copy-paste č, ć or đ in the name of a file/folder and try opening the file.
I'm using XnView v2.34 (portable).
Thanks.
Re: Can't open files/folders containing letters č, ć, đ
XnView has no native unicode support, only XnViewMP
suppertime
Alright, thanks.
