Let the user rotate a pic in every viewing mode
loth
Post by loth »
moin,
in browser mode, the user can rotate a pic via the context menu or the shortcuts.
when viewing a pic (fullscreen in my case) not.
i suggest to let the user rotate a pic in every viewing mode, as a new feature :-)
loth
Olivier_G
Post by Olivier_G »
Right: JPEG Lossless transformations directory should be available while viewing.
I believe that 'Edit IPTC data', 'Set as wallpaper', 'Print' and 'Describe' should also be available.
Olivier
Olivier_G wrote:Right: JPEG Lossless transformations directory should be available while viewing.
In context menu?
Olivier_G
Post by Olivier_G »
xnview wrote:In context menu?
Yes... (if everyone agree).
Olivier
Olivier
From my point of view, only the most important functions should be available in the context menu. I agree with 'Print' and 'Describe'. Are 'Edit IPTC data' and 'Set as wallpaper' also used often?
Olivier_G
Post by Olivier_G »
Agreed:
=> Yes for 'Edit IPTC Data', as one could/should view images one after the other in order to add specific IPTC words based on the content of the image.
Personally, I don't care that much about: 'Describe' and 'Set as wallpaper'...
Olivier
loth
Post by loth »
from my point of view, the user himself should be able to set the context-menu as he like to have it.
ofcourse, a default set (which we try to discuss here?) after installing xnview, but if the user likes to have a common or an extravagant context-menu he should be able to manage it via a special menu "arrange the X-menu" or something like that.
i, personally, need all picture options/function like rotate/flip/rename/etc in the context menu without a sub-menu, which is the case on "jpeg loseless tansformations" (which leads into an extra *click*, which takes extra time)
loth
loth
Post by loth »
this was postet before quite a while,
and i'm still in need for this little feature a lot of times and always have to switch from view-mode the browser-mode, if i want to rotate a picture quickly. so there is no "quickly" :-)
any chance to implement this? or let the user choose its own right-click menu-entries?
maybe additional to the default-entries?
config:
show additional menu-entries:
[x] looseless JPEG-rotation
[ ] set as wallpaper
[ ] print
Menus as text---
:arrow: loth
:) Hello !
• You might have a glance IN THAT THREAD and in THIS POLL…
and see too the ORIGINAL THREAD related to that poll…
:mrgreen: VG
loth
Re: Let the user rotate a pic in every viewing mode
Post by loth »
loth wrote:PostPosted: Sat Aug 27, 2005 7:50 am Post subject: Let the user rotate a pic in every viewing mode
wow! it took 3 years, but finally, it is included :-)
thanks!
thanks!
Sorry but the list of requests if very long, so i can't add all in each new versions
