Lost ability to thumbnail ts files in 0.76
gouache
Post by gouache »
As per title, XNView MP 0.76 will no longer thumbnail .ts TV recordings. Even if I uninstall and reinstall 0.75 it does not fix the issue. XNView still thumbnails .ts so it's not an issue with my system.
Re: Lost ability to thumbnail ts files in 0.76
gouache wrote:As per title, XNView MP 0.76 will no longer thumbnail .ts TV recordings. Even if I uninstall and reinstall 0.75 it does not fix the issue. XNView still thumbnails .ts so it's not an issue with my system.
you means that 0.72 was able?
gouache
Post by gouache »
I do not have a 0.72 version to try, can you link (64 bit)?
Somewhere Old versions ...
gouache
Post by gouache »
cday wrote: Somewhere Old versions ...
OK, I have tried it and thumbnailing .ts files is still broken (MPEG2 or H264).
but it works with which version?
gouache
Post by gouache »
It worked with 0.75, but after I installed 0.76 it broke something, as now no version works :( . XNView does work.
gouache
Post by gouache »
I tried 0.76 32 bit version and it is working. The strange thing is though that I use 64 bit ffmpeg.exe.
