Capture only results in a captured black rectangle image
Kisalise
Whenever I try to capture something, Capture brings up a black screen and results in only an image of a captured black rectangle.
Re: Capture only results in a captured black rectangle image
Which Capture mode are you using, a screenshot of your settings and of XnViewMP displaying the captured image may be helpful?Kisalise wrote:Whenever I try to capture something, Capture brings up a black screen and results in only an image of a captured black rectangle.
Seems to work for me, except for a possible querry about what 'Active window' should capture...
Windows 7 SP1 x64 XnViewMP 0.75 and 0.76
Kisalise
All four methods (Desktop, Active window, Window and Rectangle) result in images of large black rectangles with small differences in size.
Windows 7 SP1 x64 XnViewMP 0.76.1 x64
I see what you mean!Kisalise wrote:All four methods (Desktop, Active window, Window and Rectangle) result in images of large black rectangles with small differences in size.
I should have said that I tested XnViewMP x32 versions, I don't know if that could be relevant??
Edit:
And a screenshot of your selected settings for one of the modes, in case one of those settings is relevant?
I've tried on win 7 x64, and no problem. Do you had this problem in previous version too??
