How to disable message about social networks?
Karl_S
Post by Karl_S »
I just updated from XnView 2.32 to 2.34.
Sometimes when I open the application a dialog pops-up that invites me to follow on social networks.
- Is it possible to disable this?
- Was it introduced in 2.33 or 2.34?
Re: How to disable message about social networks?
You have it at each startup???
Karl_S
Post by Karl_S »
Just after updating, I think I saw it 5 or 6 times.
Whenever starting a new instance, even if there were no other instances open.
Then it appeared every now and then when starting a new instance.
I think I saw it a couple of times, say once every 5 start-ups.
Now it has been a few hours since I have yet to see it again.
Indeed I though that this was programmed so that it would appear less and less often as time passed.
very strange, you should see only one time!!!
in your xnview.ini, do you have in [start] section, LaunchTimes=2?
Karl_S
Post by Karl_S »
I currently have LaunchTimes=61 and it increases by one every time I close all XnView instances.
However I have not seen the message window since the first post I made.
Maybe it was just a temporary glitch?
