Hi I was looking for a way to browse my Windows Phone images and videos and quickly delete/organize stuff cause doing it from the phone or from File Explorer. I tried to use XnView for it but the access to the phone memory is denied (same thing from Adobe Bridge fyi).
Do you know a solution for unlocking it for XnView?
I'm on Windows 10 x64 Home, last updated today and using an updated Windows Phone 8.1 Lumia 925.
Browsing Windows Phone 8.1
Mixer
- Banned
Re: Browsing Windows Phone 8.1
No, I don't know. But as a suggestion, have you tried to run XnView as Administrator?rifter wrote:Do you know a solution for unlocking it for XnView?
rifter
I tried now but without any advantageMixer wrote:No, I don't know. But as a suggestion, have you tried to run XnView as Administrator?rifter wrote:Do you know a solution for unlocking it for XnView?
There is a problem with usb device not mounted as partition
rifter
I see.. so is that definitive or do you think there's a workaround?xnview wrote:There is a problem with usb device not mounted as partition
