-multi in code prevents creation of output folder
When -multi is included in code an output folder that doesn't already exist isn't created when the script is run:
This code runs and creates the 'output' folder if it doesn't exist:
This code fails with the message "Can't create file" if the 'output' folder doesn't already exist:
Note that the above tests have been run as described in this post but that kewbsl has tested using full paths.
