MP4 files not being imported in 0.76.1 on OSX
Sander
Post by Sander »
I am using XnView MP 0.76.1 on OSX. I just imported the SD card from my camera. All seemed to be fine, but just before emptying the card, I noticed that all *.mp4 files have not been copied.
When going through the settings, I have everything as default, MP4 is checked in the list of supported extensions.
Is this a bug, a configuration issue or a design issue? I was hoping XnView to be able to replace Picasa as cross-platform library manager but of course it needs to copy all media from the SD card to my photo drive.
Re: MP4 files not being imported in 0.76.1 on OSX
what do you have used to import?
Sander
Post by Sander »
xnview wrote:what do you have used to import?
Tools / Import and sort (but then in Dutch)
MP4 files have .mp4 extension?
Sander
Post by Sander »
xnview wrote:MP4 files have .mp4 extension?
Yes.
Yes.
i've tried from a folder with mp4, and video files are copied
Sander
Post by Sander »
It happened again.
The file DCIM/107_PANA/P1070353.MP4 was not copied during import.
XNviewMP version 0.78
Sander wrote:It happened again.
sometimes i is copied??
Sander
Post by Sander »
It was never copied, but I do not make movies with the camera every time. Just sometimes.
Sander wrote:It was never copied, but I do not make movies with the camera every time. Just sometimes.
and if you try again, same behavior?
Sander
Post by Sander »
Yes, no difference. It will only copy the files that already have been copied (and warns about that). The .MP4 file (uppercase on the SD) is ignored.
Sander wrote:Yes, no difference. It will only copy the files that already have been copied (and warns about that). The .MP4 file (uppercase on the SD) is ignored.
i've just tried, and MP4 is imported in 'other files' folder
