Image resize
CleverPig
Image resize
Post by CleverPig »
Found annoying difference between latest and previous versions
When I wanted to resize image in old version, it always put default preset for image size, like this
But now it always put there last used preset which is...
Let's say, I resized image from 1000x600 to 999x599
After that, I am trying to resize 2500x1900 image into 1800x1200, but... program automatically gives me last used preset and offer me 999x599 size and I always have to do unnecessary mouse clicks every time to return back to default preset, Otherwise I will have to compare each image size to avoid mistakes which is even more annoying, than choosing default preset manually every time.
Is there any way to setup those presets so the one you need would be always selected first?
Re: Image resize
CleverPig wrote:Found annoying difference between latest and previous versions
Which old version, i have the same behavior in 0.72
Other adjustment dialog select default, not like Resize so a bug i think...
