Mishandling of clipboard data
Mixer
Banned
Post by Mixer »
XnViewMP 0.76.1 x64 on Windows 10 x64
Screenshot of active window made with Alt+PrintScreen is pasted differently to XnViewMP and Paint.
In XnViewMP picture gets shifted (see left and right borders).
Pasted to Paint.
In XnViewMP after "Import Clipboard".
Re: Mishandling of clipboard data
how do you take with Alt+PrintScreen the current window? I have whole desktop
Mixer
Banned
Post by Mixer »
It always was like that in Windows. I wonder why you can't. Étrange. Maybe in your case you have to press Alt+Fn+PrintScreen like explained in this article - How to Take Screenshots in Windows 10?
This bug happens in 32bit Windows with 32bit XnViewMP too.
Mixer wrote:It always was like that in Windows. I wonder why you can't. Étrange. Maybe in your case you have to press Alt+Fn+PrintScreen like explained in this article - How to Take Screenshots in Windows 10?
ok, right a bug in QT API
[HYBRID BEING]
Post by [HYBRID BEING] »
Noticed this does not happen in v0.72 (seems like xnview.exe wasn't removed from my folder during update, heh), but happens in latter versions, particularly in v0.78.
Seems to be fixed in 0.84. Could someone else please check and confirm the bug fix?
sekina
Post by sekina »
xnview wrote: Wed Nov 18, 2015 4:09 pm how do you take with Alt+PrintScreen the current window? I have whole desktop
Taking a screenshot on PC is easy you can read this article it will be helpful for you.
https://jealouscomputers.com/how-to-scr ... n-windows/
