The lossless crop shortcut CTRL SHIFT Y not working
mindphaser
I'm using XvView v2.32 (classic). For some weird reason that shortcut mentioned in the title doesn't work. Do you have any idea why?
Re: The lossless crop shortcut CTRL SHIFT Y not working
In XnView 2.34 this shortcut does not exist. Update! No shortcut - no problem.
Don't trust this page: http://www.xnview.com/wiki/index.php/Vi ... rtcut_Keys
This page was last modified on 27 August 2009, at 14:32.
mindphaser
"No shortcut - no problem."
Are you kidding me? Leaving aside your sarcasm, in the wiki pages of XnView it says clearly that CTRL SHIFT Y is the shortcut for lossless crop. Why that shortcut isn't available anymore?
Because developer has decided so.
File keyboard.txt from XnView's directory:I generally support you in your despair (since this is General Support forum).
Well, you could use some older version which yet had this feature, but it has all older bugs as well.
Keyboard shortcuts:
* View
Open Ctrl+O
Open With Associated Program F3
Open With Associated Editor F4
View In Hexa Ctrl+H
Browser Ctrl+B
Reopen Ctrl+R
Close Ctrl+W
Print Ctrl+P
Save Ctrl+S
Save As Ctrl+Shift+S
Quit Ctrl+Q
Undo Ctrl+Z
Cut Ctrl+X
Copy Ctrl+C, Ctrl+Ins
Paste Ctrl+V
Canvas Size Shift+C
Crop Shift+X
Automatic crop Shift+Y
Add Text Shift+T
Red Eyes correction Ctrl+E
Import clipboard Ctrl+Shift+V
Select all Ctrl+A
Selection - Swap width & height Tab
Selection ratio - Free A
Selection ratio - Same as image D
Custom Selection C
Copy into Alt+C
Move into Alt+M
Delete Del
Rename F2
Describe Ctrl+D
Properties Alt+Enter
Edit IPTC Ctrl+I
Edit colormap Ctrl+M
Resize Shift+S
Rotate -90 Shift+L
Rotate 90 Shift+R
Rotate -90 lossless (jpeg) Ctrl+Shift+L
Rotate 90 lossless (jpeg) Ctrl+Shift+R
Vertical Flip Shift+V
Horizontal Flip Shift+H
Brightness/Contrast/... Shift+E
Adobe Photoshop Plugin Ctrl+G
Fullscreen F11, F
Original Size *
Fit window to image Ctrl+T
Fit image to window, all /
Zoom + +
Zoom - -
Lock Zoom Ctrl+NumPad /
Next File PageDown
Previous File PageUp
First File Home
Last File End
Next Page Shift+PageDown
Previous Page Shift+PageUp
First Page Shift+Home
Last Page Shift+End
Quick Slide Show Space, Pause
ShowMask M
Show information I
Tool Bar Ctrl+Shift+T
Status Bar Ctrl+Shift+B
Show Color Informations Ctrl+Shift+I
Search Ctrl+F
SlideShow Ctrl+L
Multiple Convert Ctrl+U
Sequence Convert Ctrl+N
Edit Multipage TIFF Ctrl+J
Options F12
Help F1
* Browser
Close Ctrl+W
Print Ctrl+P
Quit Ctrl+Q
Copy Ctrl+C
Paste Shift+C
Copy image data Ctrl+Shift+C
Select All Ctrl+A
Copy into Alt+C
Move into Alt+M
Delete Del
Rename F2
New Folder F7
Describe Ctrl+D
Properties Alt+Enter, Ctrl+E
Fullscreen F11
Folder Tree Ctrl+Shift+F
Preview Ctrl+Shift+P
Next Tab Ctrl+Tab, F8
Previous Tab Ctrl+Shift+Tab
Toggle Views F9
Fit Image to Window Ctrl+Shift+W
Show text file Ctrl+Shift+A
Show HexaView for unknown file Ctrl+Shift+N
Refresh Shift+R
Stop Esc
Open Ctrl+O
Open in Hex mode or View In Hexa ? Ctrl+H
Search Ctrl+F
Slide Show Ctrl+L
Start Slide Show Pause
Stop Slide Show Esc
Batch Convert Ctrl+U
Page Web Ctrl+G
Options F12
Help F1
