When I open Xnview, I have the previously viewed file(s) in the main window. I thought there was a setting to prevent this (to have an empty window), but going through the entire Options, I either missed it or it is not there. I think I remember that there is a setting, though. Also, is there any way to paste an image from the Clipboard into Xnview?
Thanks,
Hans L
Opening Xnview without previous files open
- Forum Librarian
Re: Opening Xnview without previous files open
Tools » Options... » General » Operations » Startup » Startup DirectoryHans L wrote:When I open Xnview, I have the previously viewed file(s) in the main window. I thought there was a setting to prevent this (to have an empty window), but going through the entire Options, I either missed it or it is not there. I think I remember that there is a setting, though.
Edit » Import Clipboard (Ctrl+Shift+V)Hans L wrote:Also, is there any way to paste an image from the Clipboard into Xnview?
There's also a command-line parameter:
xnview.exe -clipaste-
Hans L
Thank you very much. Works very well now.
Hans L
Hans L
