Add Text: more granular positioning
miksmith
Post by miksmith »
For the "Add Text" batch function is it possible to add a specification for:
1. justification
2. a handle for positioning (ie if you specify a position of 50,350 then you can use the bottom left handle of the text box)
Thanks!
