XnView problem with symbols in names of pictures
AutopilotNN
Post by AutopilotNN »
The program doesn't show the image in which name there are symbols of the European languages.
jährig - ä
It is impossible to open on a clique and in the program.
Most likely, the program incorrectly converts a name of the file and doesn't find it.
The glitch is observed long ago.
Win XP Pro SP3 Russian + Win 7 Pro Russian
Re: XnView problem with symbols in names of pictures
AutopilotNN wrote:The program doesn't show the image in which name there are symbols of the European languages.
jährig - ä
XnView Classic doesn't support Unicode, you can use XnView MP if it has the functions you need...
