0.76.1 Copy / Move Dialog
Pauli
Post by Pauli »
on Linux (32 and 64 Bit)
with "Show selected folder in folder tree" selected this dialog consumes a lot of CPU and takes about 10 sec to open. Not usable.
Re: 0.76.1 Copy / Move Dialog
do you have same issue in browser? do you have network drive mounted?
Pauli
Post by Pauli »
No, Thunar opens this directory within a few milliseconds. The folders are on a NTFS-Partition on the same disk, mounted via gvfs mount. This folder has about 400 subfolders.
For testing I copied the whole file structure to an Ext4 partition mounted with gvfs mount, too). There the dialog opens much faster. A difference that I just observe: In the folder-view of the toolbar (Computer, Home, ..) the Ext4 partition is displayed, the NTFS partition is not. Well, it could be an problem with NTFS-Support.
