Hi
I've tried this command
nconvert -out jpeg -wmfile overlay\GOPR3908.jpg -wmflag bottom-right -o final\atest GOPR3908.jpg
which adds a watermark overlay to an image and saves it in another directory. However no matter what I change for wmflag or use wmpos it *always* places the overlay in the top left corner.
have I done something wrong here??
thanks
mike
PS Latest version of nconvert
Watermark error with wmpos
Re: Watermark error with wmpos
Placing the the Watermark position before the Watermark file term seems to solve the problem
If you think that is not entirely intuitive given the help file listing:
... so do I...
Pierre: Would it be possible to make NConvert accept either order, or to change the order shown in the help file?
nconvert -wmflag center -wmfile watermark.jpg -o image_wm.jpg image.jpgCode: Select all
-wmfile file : Watermark file
-wmpos x y : Watermark position
-wmflag flag : Watermark position
top-left, top-center, top-right
center-left, center, center-right
bottom-left, bottom-center, bottom-rightPierre: Would it be possible to make NConvert accept either order, or to change the order shown in the help file?
miksmith
That works perfectly! I wouldnt have thought of that.
Much appreciated
m
Much appreciated
m
-wmfile must be the last commandcday wrote: Pierre: Would it be possible to make NConvert accept either order, or to change the order shown in the help file?
