Setting transparency
miksmith
Post by miksmith »
Hi
I have a limited pallete PNG with a black object on whitebackground (254 254 252) which I would like to be transparent. Ive tried this command
which works in xnview (following those steps), but doesnt set the transparent colour in nconvert.
What am I doing wrong here?! Ive tried reordering the commands but that doesnt help either. Using "transparent" DOES work but the index number can change between images so it isnt ideal!
thanks
mike
Re: Setting transparency
-transpcolor is to use with -mergealpha, there is no way in NConvert to change colormap
