from the changelog I can see that the latest XnView version (2.34) uses LibPNG 1.6.18.
As you can see at http://www.libpng.org/pub/png/libpng.html that version has some vulnerabilities.
It would be great if it could be upgraded to 1.6.19, the latest version at this moment, which fixes these issues.
Vulnerable LibPNG in latest XnView
omniplex
Re: Vulnerable LibPNG in latest XnView
If openssl + libpng team up they could beat Adobe Flash or Oracle Java in a "fixed security bugs per hour" pissing contest. Meanwhile the libpng folks claim that 1.6.19 also isn't good, but 1.6.20 is great (on the page you linked.)Karl_S wrote:It would be great if it could be upgraded to 1.6.19, the latest version at this moment, which fixes these issues.
I tried to find the PNG version string in the XnView binary, because WhatsNew.txt could be incorrect, but that failed near a promising "Application built with libpng-" string in XnView.exe. I can't tell if there is an XnView function actually using this string. Something like ffmpeg -buildconf would be nice, a list of all used external libraries together with their versions. E.g., I'd be also interested to know which dcraw version is used in XnView. Or which libjpeg. Or which libtiff.
While looking for PNG in the binary I stumbled over -i -i "%s" -y -ss 00:00:01 -vframes 1 -an -vcodec png -f rawvideo "%s", apparently XnView contains FFmpeg command line options, and one -i instead of -i -i might be good enough.
omniplex
JFTR, libpng-1.6.21-README was not a security issue.
