0.76: Renaming images doesn't resort them
Evan
Post by Evan »
When I manually rename images, they do not get into their (new) correct order, even after I try to refresh the catalog (F5).
Re: 0.76: Renaming images doesn't resort them
and with 0.81?
XnView 0.84: After renaming the image files are not resorted. Pressing F5 sorts them in sort order.
:arrow: Closed (Please post here if the problem should still occur for you.)
