Save to relative path?
Evan
Post by Evan »
[v0.76]
In the batch convert panel, I want to be able to save the files in a relative path/folder, to where the original images are.
Unfortunately, when I select output 'Source Folder', I have no other options. When I select 'Folder', I do not know how to save relative to source, the images end up in C drive.
Any ideas?
Thanks
Re: Save to relative path?
you can use Output\output_filename.jpg for example
Evan
Post by Evan »
Thanks, I now realized you need to do that in the Filename field.
For others having the same problem, set the Output option to Folder and leave it blank.
Then in the Filename field below, set the relative path.
Works great now, thanks.
