0.76: Viewer mode ignores Filter list
draphaslos
Post by draphaslos »
I've recently switched to XnViewMP from IrfanView as a photo viewer, but the standalone Viewer attempts to visualize formats it doesn't recognize, and it doesn't use the Browser file filter list without first switching from the Browser to the Viewer. This behavior makes browsing through folders with a significant amount of .exe or other types of files rather unwieldy.
If having the Viewer not load a file list filter is intended behavior, could a switch be added for it?
Re: 0.76: Viewer mode ignores Filter list
you start XnViewMP's Viewer directly from an image file or from browser?
DeFi
Post by DeFi »
Were your already able to locate this bug? I am experiencing the same behavior with XnViewMP 0.79 and did not find anything related in the bug-tracker. When I open an image file from the desktop or in explorer directly in viewer mode and start cycling the image files in the respective folder, XnViewMP will cycle through all files in the folder. This includes really all files (.lnk, .exe .obj ... etc.). The files XnViewMP can not render are displayed as blank. If I however switch XnViewMP to browser-view it first starts very slowly listing all files. After the listing is complete, it filters the files according to my settings, so only image files remain. If I now switch back to viewer-mode and start cycling the files, it only cycles the image files as intended. If XnViewMP is started in browser-mode and an image file is opened from there, it also works as intended. I find it very strange, that the filter is applied after displaying a full list of all files instead of applying it before displaying files. I hope this description is useful in fixing the bug.
DeFi wrote:When I open an image file from the desktop or in explorer directly in viewer mode and start cycling the image files in the respective folder, XnViewMP will cycle through all files in the folder. This includes really all files (.lnk, .exe .obj ... etc.).
do you have a lot of files in this folder?
See Issue 858 for current status and details.
This works fine for me in v0.84.
:arrow: Closed. Please post here in case the problem should still occur for you.
