How to maintain image position and zoom level on Next/Prev
n_how
I'm sure I used to be able to keep the Next or Previous image at the same zoom and position on screen. I'm working to check no page numbers missing in top right hand corner of large image, have to scroll zoom every page. Any tip, please, how to do it? UPDATE: Please ignore this post, it's the X/Y Reset in View options that does it.
Re: How to maintain image position and zoom level on Next/Pr
In XnView Classic View > Lock Zoom locks the zoom setting, and in a quick test also seems to lock the position...n_how wrote:I'm sure I used to be able to keep the Next or Previous image at the same zoom and position on screen. I'm working to check no page numbers missing in top right hand corner of large image, have to scroll zoom every page. Any tip, please, how to do it?
You are using XnView MP, which also has a View > Lock zoom setting, and also a Tools > Settings > View > View tab -- Reset XY (not fit) option?UPDATE: Please ignore this post, it's the X/Y Reset in View options that does it.
