Please update x64 Setup Files
defchris
Post by defchris »
there's the update notification popping up in XnView MP 0.72 x64 on Windows now for quite some time. But when I download the new setup to update, the setup file only installs "0.72". I haven't tested the 32-bit versions but the zip file contains 0.76.1.
Is it possible you could update the setup file, please?
TIA
Re: Please update x64 Setup Files
you means that setup for x64bits is the 0.72??
this link?
http://download.xnview.com/XnViewMP-win-x64.exe
defchris
Post by defchris »
Hi sorry for the delay,
yes. I've downloaded that file several times from http://www.xnview.com/en/xnviewmp/ and installed it. The size is of the setup file is 33.5 MB / 35,164,728 bytes.
But the program's "About" still shows "Version 0.72 x64 (Dec 19 2014)", even after uninstalling the existing MP.
The x64 zip file is 45.4 MB / 47,675,895 bytes of size and contains version 0.76.1.
i've installed http://download.xnview.com/XnViewMP-win-x64.exe, and i have 0.76
defchris
Post by defchris »
Hello again,
sorry for bothering. For some reason the old version was not completely uninstalled upon replacing 0.72. After deleting the folders in the AppData\Roaming and the rest of the Program files, I reinstalled the 0.76.1 which now runs without asking for an update.
