Viewer incorrectly reads size of embedded RAW preview
AXO
Post by AXO »
With option "Camera RAW, use" set to "Embedded preview" RAW files opened through Browser tab and viewed in 1:1 mode are correctly scaled (i.e. usually are smaller than RAW).
However, when the same file is viewed again from Viewer tab through Next file or Previous file option, embedded RAW preview is upscaled in 1:1 mode (probably to RAW data resolution) and "Pan tool" is bugged.
Also noticed that "View > Real Size (Ctrl + /)" sets wrong size on RAW files opened through Browser, but "100%" button on Viewer toolbar (1:1 icon) works correctly (but breaks when previous or next file is opened from Viewer).
