Shortcut Exif Rotate
esa1966
Post by esa1966 »
Dear,
I really appreciate xnview.
I use XNview and my most used functionality is to browse my picture and make essentially two actions on it :
1) delete bad or duplicated picture.
2) rotate pictures based on EXIF
The first action is realised very quickly using the DEL key.
The second action require to use the mouse and go in toolbar to select the function.
I know that I can program a batch conversion on all the file in a folder. But in this case, all files will be altered.
I prefer to browse my folder and rotate only pictures that need to be rotated.
Is it possible to define a keyboard shortcut for EXIF rotation?
Thank
Karl02
Re: Shortcut Exif Rotate
Post by Karl02 »
Yes, a shortcut for a transformation according to the EXIF orientation tag would be good.
In your case it should be possible to select all images and then start this function with the mouse.
See also:
http://newsgroup.xnview.com/viewtopic.p ... 552#p86977 Lossless rotate question (2010-09-22)
-- Karl
