I would like to use the Descrip.tion file generated in XNview in my own program - is there a summary of the file format available? What are the limitations as far as number of characters, number of entries?
many thanks,
Wolfgang
Descript.ion file format
Re: Descrip.tion file format
i don't think that there is a limitation of characters, here is
http://jpsoft.com/ascii/descfile.txt
- Forum Librarian
- XnView Classic
- XnView MP
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#File]File[/url]) wrote:
HiddenDescription
- When enabled, XnView will hide descript.ion files by setting the hidden attribute to the descript.ion files when writing them.
Value: Boolean (1/0), enabled by default
Wolfgang Ziegler
Pierre, XnTriq
thanks a lot - this is what I was looking for.
Is it correct that the quotes around file name are optional and must be used to allow "liberal file names" with spaces etc?
regards,
Wolfgang
regards,
Wolfgang
- Forum Librarian
Let me know if the info provided in the following topics answers your question, Wolfgang. If not, I'll keep digging for more.Wolfgang Ziegler wrote:Is it correct that the quotes around file name are optional and must be used to allow "liberal file names" with spaces etc?
