Remove toolbar and hide menus question
guest70
Post by guest70 »
Hello, i want to use a couple windows with refereces for 3d modelling and the toolbar/menus are just a waste of space...is there any way to hide/remove when previewing images?
Thank you
Re: Remove toolbar and hide menus question
guest70 wrote:Hello, i want to use a couple windows with refereces for 3d modelling and the toolbar/menus are just a waste of space...is there any way to hide/remove when previewing?
When viewing thumbnails in the file browser, or stepping through images in the viewer?
In either case there are some options in the View menu to customise the interface, including hiding the toolbar, or you could experiment with using full screen mode if that might be useful...
