When you set BMP and ICO files to open with XnView MP and open files, you get empty XnView window.
Example XnView MP 0.76.1 64-bit (empty window when opened)
http://webmshare.com/vAy8W
Although Drag & Drop to XnView window works.
Example IrfanView 4.41 32-bit (works)
http://webmshare.com/XNm53
BMP and ICO files cannot be opened directly from Explorer
CreativeWorld
CreativeWorld
Re: BMP and ICO files cannot be opened directly from Explore
Can I get a reply please confirming this issue?
CreativeWorld
I still have this issue on XnViewMP Version 0.78 x64 (Jan 12 2016)
Erixx haxx
Hi:
What O.S are you using ??
I just tried both file types and they open fine for me.
Win7x64Pro
v0.78x64
Win7x64Pro
v0.78x64
CreativeWorld
Windows 8 64-bitErixx haxx wrote:What O.S are you using ??
Erixx haxx
Another question after seeing this post.
Does enabling the setting for XnviewMp to "Startup with file" in fullScreen change anything ??
-General
--Startup
Here:
http://newsgroup.xnview.com/viewtopic.php?f=62&t=32709
Reason: I'm not setup to open files with xnview anymore
-General
--Startup
Here:
CreativeWorld
Your answer is totally unrelated to this issue and doesn't solve it.Erixx haxx wrote:Another question after seeing this post.
-General
--Startup
Here:
Erixx haxx
Their is 3 different modes files can be opened into. "Browser" "Fullscreen" "Viewer"
Hence the post about viewer mode being bugged and might have been related if files opened inside one mode but not the other.
Someone else has already confirmed these 2 files types won't open in either mode on win 8..
Here:
http://newsgroup.xnview.com/viewtopic.php?f=82&t=32708
Here:
if you drag&drop bmp/ico on the XnViewMP's icon, same problem?
