PhotoFiltre
All non-XnView related: softwares, formats, imaging, photography...
Lesmo16
PhotoFiltre
Post by Lesmo16 »
PhotoFiltre 6.2.0 - Freeware:
PhotoFiltre is a complete image retouching program. It allows you to do simple or advanced adjustments to an image and apply a vast range of filters on it. It is simple and intuitive to use, and has an easy learning curve. The toolbar, giving you access to the standard filters with just a few clicks, gives PhotoFiltre a robust look.
Version 6.2.0 (November 2005)
- the buttons of r?age (+) and (-) are cancelled mutually (automatic Undo)
- Am?oration of the Propri?s function of the image (posts the infos Exif/IPTC/Commentaire)
- Bo?s of dialogue of opening and recording am?or?
- Correction of bugs
Homepage:
http://www.photofiltre.com/
Screenshot:
http://photofiltre.free.fr/utilitaires/ ... filtre.htm
:arrow: New release of PhotoFiltre available - updated to 6.13
ckit
Post by ckit »
Thanks!
Thanks, Lesmo! Let's post all news for PhotoFiltre in this thread.
Lesmo16
Post by Lesmo16 »
:arrow: New release of PhotoFiltre available.
30/8/2005 - PhotoFiltre 6.1.4 : bug fixing when saving JPEG with EXIF/IPTC
Everyone who believes in telekinesis, raise my hand!
Lesmo16
Post by Lesmo16 »
23/9/2005 - PhotoFiltre 6.1.5 : bug fixing when saving GIF with transparency
Lesmo16
Post by Lesmo16 »
Version 6.2.0 (Novembre 2005) - for download link see first post
- Les boutons de réglage (+) et (-) s'annulent mutuellement (Undo automatique)
- Amélioration de la fonction Propriétés de l'image (affiche les infos Exif/IPTC/Commentaire)
- Boîtes de dialogue d'ouverture et d'enregistrement améliorées
- Correction de bugs
Perhaps somebody is able to translate the changelog - my Swedish isn't that good. :mrgreen:
Translated---
:D Hi Thomas !
This could be something like :
« - The “+” and “–” adjustment buttons cancel one another (automatic Undo)
- Improvement of the function "Image Properties" (Displays EXIF / IPTC / Comment information)-
- Improved "Open" and "Save" dialogue-boxes.
- Bug fixes… »
:mrgreen: V.G.
Lesmo16
Post by Lesmo16 »
Claude, thanks for the partial translation. :P
You left that out ...
... so it seems to me as if your Swedish is limited, too! :mrgreen:
OUPS !
Image Forgotten!
- It's fixed up now…
:mrgreen: VG
ckit
Post by ckit »
ckit wrote:PhotoFiltre 6.2.0 is now out!
Also in the Plugins manager run "Check for Plugin Updates"
This has been reported before, ckit, but thanks, anyway. :-)
ckit
Post by ckit »
PhotoFiltre 6.2.1 - Freeware:
Version 6.2.1 (February 2006)
- Lecture/?iture of value DPI in the Exif/Jpeg block
- the Tampon tool of Motif/Fixe holds account of the size r?le reason (use as brush)
ckit
Post by ckit »
PhotoFiltre 6.2.2 - Freeware:
Version 6.2.2 (February 2006)
- Correction of a bug at the time of the recording in JPEG
ckit
Post by ckit »
PhotoFiltre 6.2.3 - Freeware:
Version 6.2.3 (Mars 2006)
- Correction of a bug in the undo Text
ckit
Post by ckit »
PhotoFiltre 6.2.4 - Freeware:
A complete image retouching program. It allows you to do simple or advanced adjustments to an image and apply a vast range of filters on it. It is simple and intuitive to use, and has an easy learning curve. The toolbar, giving you access to the standard filters with just a few clicks, gives PhotoFiltre a robust look.
Version 6.2.4 (April 2006)
- Better compatibilit?ans the opening of format tiff (Revision 6)
- A new the possibilit?e num?ser in black and white (Twain)
- Possibilit?' to record in JPEG level of gray 8 bits
- Correction of a bug in the posting of the checkerwork of transparency
- larger pr?sion in the module of impression
- Format EPS temporarily supprim?trop of bugs)
