0.78 Image size (WxH) in status bar disappeared?
TrillianaEM
Post by TrillianaEM »
I just installed version 0.78, and opened an image file to check request no. 490 (full file name displayed in status bar). The file name is displayed all right now after adding the line "maxCharsFilename=999" in the settings file. This is very good, thank you. :D
But now the image width and height are missing, they are gone. :( I see on the left end of the status bar only the file index per total number of files in the folder, the file name and the current cursor position.
I can display the image width/height in the title bar, but it is badly readable (black on dark grey), besides I'm used to see it in the status bar, when changing the image size. The setting for "Displayed informations" on tab "Informations" under "Image View" seems to have no effect.
Cheers & best wishes
Trilliana
slacocheho
Re: 0.78 Image size (WxH) in status bar disappeared?
Post by slacocheho »
There're no file size and no file dimension.
The older versions in this page do not work, all have qt4 error something when opened.
Download sites either provide the latest version of XNViewMP or very old version of XNViewMP.
Now I can't work because of this. I should've made backup of the old installer..
What a bad weekend :(
See Issue 791 for current status and details.
Image width&height are shown in the statusbar (XnView MP 0.84)
Note that there is still a problem with maxCharsFilename in statusbar of Viewer; there is a separate bug report for this. See 0.53: Filename in status bar.
:arrow: Closed
