scrolling up and down through directories
pikeface999
Post by pikeface999 »
IMAC Elcaptitan
xnview mp version 0.78
Weh I first load xnviewer mp scrolling up und down to select directories with photos in is fine and scrolling is smooth. After about 10 mins the scrolling becomes very jerky any suggestions please
Mixer
Banned
Post by Mixer »
pikeface999 wrote:suggestions please
Suggestion: you learn to read and start posting questions related to XnView MP in subforum dedicated to XnView MP, NOT XnView Classic which is for Windows only.
pikeface999
Re: scrolling up and down through directories
Could this be the size of my HDs or the amount of my images on the HDs ?
HELP
Mixer
Banned
Post by Mixer »
Every part of window which experiences frictions must be properly oiled to provide smooth scrolling. Please visit Apple tech service station to get treatment for scrolling sliders of your Mac.
Or, if I got general support pattern right, helping procedure is like following:
1) strange
2) your scrolling becomes very jerky?
3) could you send me the file?
pikeface999
The rest of mac scrolling is perfectly fine.
From your descriptions "2) your scrolling becomes very jerky?"is what is happening.
What file should I send you and how please ?
and you had not that in 0.76?
pikeface999
The problem existed before 0.76
Is there an archive where I could download some earlier versions to see if the problem goes away.
pikeface999 wrote:The problem existed before 0.76
Is there an archive where I could download some earlier versions to see if the problem goes away?
http://download.xnview.com/old_versions/
pikeface999
Ok thats sorted the problem I have gone back to -:
XnViewMP
Version 0.72 x64 (Dec 19 2014)
Libformat version 6.64
Toolbar icons from mezich (no use without authorization)
Logo & app icon from thibaud
File-type icons from budz45
INI filename: /Users/Bean/.xnviewmp/xnview.ini
are you able to make a screenrecord to show problem?
pikeface999
Nothing to screen capture.
All that I can say is that now the scrolling up and down through the directories is smooth, where as with subsequent versions after a 5 mins the scrolling became very jerky. The other thing that I have noticed is that the caching of previously viewed images is much faster to re view them.
