xnviewmp.exe entrypoint not found error
gwerdi
Post by gwerdi »
Good evening
Since a while I got an error message when I start xnview MP on an old Windows XP computer. The message is in german so i try to translate in english:
the procedure entry point "InitializeCriticalSectionEx" could not be located in DLL "KERNEL32.dll"
If i confirm the message, xnview MP starts.
The other problem is, when i want to start the file type association tool in the settings - systemintegration I get the "run as..." prompt. Confirming it and nothing happens. The same happens when i start the "Associate files with XnViewMP.exe" directly.
I just upgraded to the latest xnviewMP version and I got the same problem.
Is this a known problem?
Erixx haxx
Re: xnviewmp.exe entrypoint not found error
Post by Erixx haxx »
