Real bug: under Vista canntos set File Associations. Field is inactive.
Vista 32bit, all updates.
Under Vista canntos set File Associations
Galnospoke
Re: Under Vista canntos set File Associations
windows file association is only available on Win 7/8/10. You need to use checkbox above
Galnospoke
Eee...? Are You sure??? When I use Application Verifier and "hack" Xnview into Windows 7 I can register all extensions. Without it I cannot do it. IMHO Vista has exactly the same extenstions engine as 7.
