Fuzzy thumbnails
3x5
Fuzzy thumbnails
Hi, I have noticed that thumbnails look good up to 192x144. Bigger than that, they look fuzzy. Even regenerating thumbnails doesn't help. Is there anything I can do to fix this?
Re: Fuzzy thumbnails
you need to check in catalog>thumbnail size
3x5
Thanks so much.
edit: Although I should mention that this only sharpened some thumbs. Others stayed fuzzy. If I go into a folder and select view > update catalog from files, only some will be fixed.
