Update XMP sidecars erase Lightroom info
Sirio
Post by Sirio »
Hi.
I am using the “menu View > Update files from database” function to add keywords, but it's a problem:
When I transfer my photos from my SD card to my computer, I have two files: the RAW and the JPG. I import those files in Lightroom and make the colour corrections and other settings. When I quit Lightroom all those settings are memorized inside an XMP sidecar file. In this case, if I lose my Lighroom database or I send my photos to another colleagues, his Lighroom will open the RAW files with all my settings and development modifications.
Now I have 3 files: RAW+JPG+XMP side by side.
I open now XnViewMP to give them keywords by the Categories.
After done, I make: “menu View > Update files from database”
And appear a disaster, because the XMP file is not really “updated”, but “replaced”. :(
So, when I re-open my files in Lightroom, all my settings and development modifications are lost ! :shock:
Is it possible that the Update files from database function, will update only the keyword section of the XMP file? And let all the data in the other sections created by others softwares, untouched?
Thanks
Sirio
Re: Update XMP sidecars erase Lightroom info
could you send me an example file?
Sirio
Post by Sirio »
Yes
Here the links to download the RAW+JPG and two XMP files:
TestXMPLightroom-001-Lightroom.xmp ---> is made by Lightroom, it has development settings personalised.
TestXMPLightroom-001-XnViewMP.xmp ---> is the same as above passed in XnViewMP added some keywords then "View > Update files from catalog"
https://www.dropbox.com/s/jcpdzrxxilk3y ... 1.JPG?dl=0
https://www.dropbox.com/s/6hkq096jvtuxa ... 1.RW2?dl=0
https://www.dropbox.com/s/8fh7xbypq1rxq ... m.xmp?dl=0
https://www.dropbox.com/s/38udec212oano ... P.xmp?dl=0
Sirio
See Issue 815 for current status and details.
Sirio
Post by Sirio »
Wonderful, Thank you, Pierre. :D
I hope see soon the new 0.79 release.
Have a nice day.
Sirio
