My portable XnviewMP is constantly accessing HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\}\PropMMDevices\Audio\Render at a rate of app. 5 hits per seconds.
Why is this?
0.78 Constantly accessing registry
Re: 0.78 Constantly accessing registry
i don't know
jadO
This seems to be my HD Audio Device ( Sound card). When I remove it, XnvieMP stops accessing it.
I don't even see failed attempt in process monitor then.
If I reactivate it, it starts all over again. It happens when I select a video file, avi or mp4. It does not happen with flv.
- Forum Librarian
Have you tried adding localservice and networkservice to the administrator group, jadO?
PC Gamer: [url=http://www.pcgamer.com/the-most-frustrating-windows-7-audio-problem-solved/]The most frustrating Windows 7 audio problem solved[/url]) wrote:What's happened is that the something has changed a registry value which give users rights to make changes to the Windows audio process. And in this case 'users' doesn't refer to people logging into your machine, it's other programs as well. By locking them out of the process in question, they can no longer playback sound.
You can check this by opening up Regedit and going to HkeyLocalMachine>Software>Microsoft>Windows>CurrentVersion>MMDevices>Audio>Renderer and right clicking any of the keys in this stack. In the Permissions tab of the properties dialogue, there should be a user called 'AudioEndpointBuilder' and another one called 'Audioserv'. If they aren't present, something has gone awry.
jadO
Thanks for trying to help.XnTriq wrote:Have you tried adding localservice and networkservice to the administrator group, jadO?
Unfortunately both users are present in my registry.
When I check Process Monitor also it is successfully at accessing the desired key. The issue is, that it keeps accessing it like 100 time per minute.
I don't see a reason for this. I could understeand if it accesses it 1 time but not multiple times and constantly firing.
