Earlier releases of xnview (at least 1.5) allowed use of the arrow keys on the keyboard to move from one image to the next (in a directory.) Is this something that can be optionally enabled in the newer (1.8+) versions (I don't like to use the mouse for this ?)
Also, how does one disable decoding of .NEF files so that only the embedded JPG image in a .NEF file would be displayed (which is much faster and sufficient for quick visual scan when you have a large number of images to go through ?)
Thanks for any suggestion !
Use of (left/right) arrow keys to switch betweein images
Re: Use of (left/right) arrow keys to switch betweein images
I'll add an option for that.Sassan wrote:Earlier releases of xnview (at least 1.5) allowed use of the arrow keys on the keyboard to move from one image to the next (in a directory.) Is this something that can be optionally enabled in the newer (1.8+) versions (I don't like to use the mouse for this ?)Also, how does one disable decoding of .NEF files so that only the embedded JPG image in a .NEF file would be displayed (which is much faster and sufficient for quick visual scan when you have a large number of images to go through ?)Options/View/Keyboard
