Don't know how to debug this and what additional information is useful. Reproducible 100% of time.
Factsheet:
1) Thumb.db size is 1,2GB, XnView.db size is 96MB
2) working set is around 2,5GB too
3) if I delete/move/rename the XnViewMP in Roaming the memory usage is back to normal
4) I have added a huge folder to the catalog recently
5) moving Thumbs.db and XnView.db away from XnViewMP folder does not improve memory usage.
6) setting "session=" and "RecentFiles=" in xnview.ini manually fixes the problem.
Windows 7 x64 SP1
Invalid report. 0.78 x64: 2,5GB of private process memory
Alt Bass
Alt Bass
Re: 0.78 x64: 2,5GB of private process memory at startup
Disregard this. I had tab bar disabled, and I discovered many images being opened because I did not close them after I reenabled the bar.
The report is invalid.
