Fullscreen image filtering
r3incarnat0r
Post by r3incarnat0r »
I would like to ask, if it's possible, when viewing on fullscreen, to display an image after it's filtered (or make an option to set so). Current behavior is that when I switch to a next image, first a pixelated image is quickly drawn and after that redrawn smoothed. It's mostly noticebale if I switch images too fast or go backwards (if the image I switched to isn't cached). To me it has annoying feel, also I think it would look much nicer a serious, for example when I do some photo presentations, to display images right away in their final states, instead of annoying redrawing.
Thanks!
Re: Fullscreen image filtering
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=127167#p127167]NAvigation using the mouse wheel[/url]) wrote:You can edit xnview.ini and change the value for prevSize in the [Viewer] section to @Size(0 0).
