Auto image size
Octopuss
Auto image size
Post by Octopuss »
Could you add 100% zoom into Auto image size? OR alternatively make the program remember the last zoom level used?
Re: Auto image size
Octopuss wrote:Could you add 100% zoom into Auto image size?
View > Real size, or which setting?
Octopuss wrote:... OR alternatively make the program remember the last zoom level used?
+1
oops66
Re: Auto image size
Post by oops66 »
cday wrote:... OR alternatively make the program remember the last zoom level used?
+1 too (for last zoom level and area used ?)
Octopuss
Re: Auto image size
Post by Octopuss »
cday wrote:View > Real size, or which setting?
The dropdown menu called "Auto image size". I think it's even in the toolbar by default.
Re: Auto image size
You are asking to add Real size (=100% zoom?) which is already a separate option in the View menu and an available icon on the toolbar, to the View > Auto image size options?
Octopuss
Re: Auto image size
Post by Octopuss »
MAYBE.I think so. I mean the menus start to get a bit confusing after digging in them for a while :P
But making Xn remember last zoom level is probably more useful. I tried experimenting with the auto zoom level and "lock zoom" feature, but it was no use. I don't think it even remembers the locked zoom.
Octopuss
Re: Auto image size
Post by Octopuss »
bump
