Website creation with images from various folders
sean_gut
Hi there, I am using this nice software for several months and I think it is very great. I use it to make myself some html thumbnail pages for my pics. The problem is that the html function only works in one folder. I have a lot of sorted pictures in different folders and I wanted to have a thumbnail page with the pics from that different folders. Is there a way to realize that?
At the moment, the web page creation is limited to the files (images) located in one directory.
One might try some workarounds, but none does work:
- Gathering file links to images in one directory and then create the web page, but this doesn't work (error messages).
- A search result can consist of file from various directories, but creating a web page based on the search result will not work (error messages).
Think there should be a common way for slide shows, web pages, and contact sheets to select the input files.
