MP-0.78x64Linux: Web Capture issues
oops66
Post by oops66 »
I just noticed some errors with "Create/Web Capture..." (in some "jquery" pages), is it normal?
For exemple, here:
http://webdesignerwall.com/demo/html5-grayscale/
or here:
http://jsfiddle.net/bG4gR/
PS: And if I use several times this functionality, the memory is saturated and the swap disk switches "on" (even if I close the XnViewMP windows/tabs)... so I suspect some memory leaks ?
Re: MP-0.78x64Linux: Web Capture issues
currently i use old Webkit engine, but i must use new Qt Web API
oops66
Post by oops66 »
xnview wrote:currently i use old Webkit engine, but i must use new Qt Web API
Merci pour l'information Pierre.
