Whenever I try to open a file from a network share (SMB) with the option 'open with', the program is started, but the file/picture is not loaded. When I try it with a file located locally, it is working.
With 'XnView for Windows" it is working.
Regards,
foxy
0.78 Windows 10 - SMB - Open with not possible
Re: 0.78 Windows 10 - SMB - Open with not possible
and if you drag&drop this smb file on XnViewMP's icon?
