I have scanned over 5000 family photos in 300+ folders and organized the folders with the following "yyyy-mm-dd folder name" ie: 1998-12-25 Christmas with the family
Is there any way for me to automatically change the photos metadata info date taken/created/modified based on the date in the folder?
Also, what metadata field should I change for most programs (including google photo online) so when it organizes by date it will see the date I want and not when I scanned it?
Thank you
automatically change metadata date on scanned photos
ChaseMc
Re: automatically change metadata date on scanned photos
no, no way to use a folder name as date
- Forum Librarian
Phil Harvey ([url=http://u88.n24.queensu.ca/exiftool/forum/index.php/topic,4471.msg21647.html#msg21647]Renaming files according to current directory structure[/url]) wrote:The command is exiftool "-alldates<$directory 12:00:00" DIRebony111 wrote:I have sense organized the files into the following structure user/images/yyyy/mm/dd, and i would like to run a command to change the exif dates to correspond to the file structure.
(use double quotes as above in Windows, or single quotes in Mac/Linux)
ExifTool uses some magic to pull any numbers that look like a date/time out of whatever string you assign to a date/time tag.
