Sorry if this topic has already been covered, I searched for it but didn't find anything on it. My issue is, when I'm working in Adobe After Effects and my file is in an open XnView MP folder, then After Effects either won't save the file I'm working on, or it will only save it by renaming it. So it doesn't want to overwrite a file that's currently being viewed in MP, it seems. Is there any setting in MP that will fix this? I'm using the Windows version of AE CC 2015, if that helps.
Thanks
Adobe files not saving when part of an open MP folder
showmeinfinity
Re: Adobe files not saving when part of an open MP folder
strange, some users have sometimes a similar problem with photoshop...
