XnView could not determine jpeg type
Prebral
Post by Prebral »
I have recently reinstalled XnView on my new Acer Nitro17 with Windows 10. However, it does not open some of my photos that it managed to process in previous installation.
It seems that it has problems with large jpgs (scans of my large format negatives). It was able to display a thumbnail, but when I tried to open the file, I got warned that I have not enough memory. That is weird, because my new notebook has more physical memory and better graphics card than the previous one, but I thought that maybe there is a problem with graphic card and forced XnView to use Nvidia and not Intel manually using windows context menu.
After that, a new kind of error popped up - suddenly, XnView can not determine type of these jpg files, although it porcesses other jpgs alright. I tried to check "Display all image types" as suggested by the error message, but nothing changed.
Any idea, what may be causing it? I had no problem with the same kind of file in an older version of XnView.
Re: XnView could not determine jpeg type
Prebral wrote:I have recently reinstalled XnView on my new Acer Nitro17 with Windows 10. However, it does not open some of my photos that it managed to process in previous installation.
As XnView Classic is 32-bit software there is a limit to the memory can address, which can be reached when an image has particularly large pixel dimensions, you were able to open the exact same files previously with Classic?
If that could be the issue you could try using XnView MP 64-bit, or see if the problem also exists with other 32-bit programs...
Prebral
Post by Prebral »
Thank you, MP 64bit works fine.
