Import and Sort doesn't work
redtex
Post by redtex »
Platform: Windows 10 Prof 64bit and Fedora 23 Gnome 64bit
XnView MP version: 0.79 x64 (Mar 22 2016)
I'm trying to use "Import and Sort" tool.
No matter, which settings I use, there are always the same result - process hangs with 24% of completion, no files actually imported. Screenshot in attachment.
Re: Import and Sort doesn't work
and what do you have in source folder?
redtex
Post by redtex »
Hi !
I've created for test purposes folder named 'in', and put some files in two subfolders:
/home/wadim/in
├── bebe
└── meme
├── 23072011019.mp4
└── 28012011.mp4
See Issue 831 for current status and details.
This problem is supposed to be fixed in XnView MP 0.80 or later. Could you please try and confirm the bug fix, redtex?
