Hi!
I tried to install the new version of XnViewMP (0.79) in ubuntu. It was the installation but did not start the program. After much searching I found that missing the libgstapp-0.10.so.0 library, which was not easy to find. Could not be included in the installation package to prevent this problem?
Ubuntu: Problem to start the program
oops66
Re: Problem to start the program.
Hi, ... +1 (I think,statics libraries are needed to have XnViewMP into multi-platforms, even for olds distributions)mnwstl wrote:Hi!
gagala
Got the same problem with installation of Xubuntu 16.04. Until now I've never had that problem. libgstapp-0.10.so.0 really should be included to the installation file. Not everybody has the skills and time to seek for information to get help.
Found a solution:
sudo add-apt-repository ppa:dhor/myway
sudo apt-get update
sudo apt-get install xnviewmp
Found a solution:
sudo apt-get update
Klaas
Yes, the very same problem here after upgrading Xubuntu to 16.04 today…
I solved it with:
I found that here.
I solved it with:
apt install libgstreamer-plugins-base0.10-0-
mpeca
XnView 64bit DEB file don't start after installation on Debian 8.4 (64bit, of course). Why?
Many thanks.
massimo
Many thanks.
massimo
mpeca
[SOLVED] Re: Problem to start the program.
I have installed libgstreamer-plugins-base0.10-0 from Synaptic and now work fine. But there isn't any information on instructions information. Only for Microsoft Windows there is all, XnView staff?mpeca wrote:XnView 64bit DEB file don't start after installation on Debian 8.4 (64bit, of course). Why?
Many thanks.
massimo
Bye.
massimo
mdalacu
I cannot start it on Ubuntu 16.10, it hangs on startup. I see nothing in terminal except:
With sudo xnview it works.
On older Ubuntu versions it was working just fine.
** (XnView:25057): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-YFmApRS67f: Connection refusedOn older Ubuntu versions it was working just fine.
mpeca
the same problem occurs with version 0.84, but this time I have not solvedmpeca wrote:I have installed libgstreamer-plugins-base0.10-0 from Synaptic and now work fine. But there isn't any information on instructions information. Only for Microsoft Windows there is all, XnView staff?mpeca wrote:XnView 64bit DEB file don't start after installation on Debian 8.4 (64bit, of course). Why?
Many thanks.
massimo
Bye.
massimo
which message do you have in console?mpeca wrote:the same problem occurs with version 0.84, but this time I have not solvedmpeca wrote:I have installed libgstreamer-plugins-base0.10-0 from Synaptic and now work fine. But there isn't any information on instructions information. Only for Microsoft Windows there is all, XnView staff?mpeca wrote:XnView 64bit DEB file don't start after installation on Debian 8.4 (64bit, of course). Why?
Many thanks.
massimo
Bye.
massimo
Re: Ubuntu: Problem to start the program
sorry a terminalmpeca wrote:excuse my ignorance: what console?
mpeca
the same problem occurs with version 0.84, but this time I have not solved[/quote]
which message do you have in console?[/quote]
I have installated with Gdebi on Debian 8.7 (not on Ubuntu) with LXDE
